MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
list=watchlist (wl)
- Denna modul kräver läsrättigheter.
- Denna modul kan användas som en generator.
- Source: MediaWiki
- License: GPL-2.0-or-later
Hämta de senaste ändringarna på sidor i den nuvarande användarens bevakningslista.
- wlallrev
Include multiple revisions of the same page within given timeframe.
- Type: boolean (details)
- wlstart
The timestamp to start enumerating from.
- Type: timestamp (allowed formats)
- wlend
The timestamp to end enumerating.
- wlnamespace
Filter changes to only the given namespaces.
- Värden (separerade med | eller alternativ): 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 2300, 2301, 2302, 2303
- To specify all values, use *.
- wluser
Only list changes by this user.
- Typ: användare, genom något av användarnamn, IP-adress, interwikinamn (t.ex. "prefix>Exempelnamn") och användar-ID (t.ex. "#12345")
- wlexcludeuser
Don't list changes by this user.
- wldir
In which direction to enumerate:
- newer
- List oldest first. Note: wlstart has to be before wlend.
- older
- List newest first (default). Note: wlstart has to be later than wlend.
- Ett av följande värden: newer, older
- Default: older
- wllimit
How many total results to return per request.
- Type: integer or max
- The value must be between 1 and 500.
- Default: 10
- wlprop
Which additional properties to get:
- ids
- Adds revision IDs and page IDs.
- title
- Adds title of the page.
- flags
- Adds flags for the edit.
- user
- Adds the user who made the edit. If the user has been revision deleted, a userhidden property will be returned.
- userid
- Adds user ID of whoever made the edit. If the user has been revision deleted, a userhidden property will be returned.
- comment
- Adds comment of the edit. If the comment has been revision deleted, a commenthidden property will be returned.
- parsedcomment
- Adds parsed comment of the edit. If the comment has been revision deleted, a commenthidden property will be returned.
- timestamp
- Adds timestamp of the edit.
- patrol
- Tags edits that are patrolled.
- sizes
- Adds the old and new lengths of the page.
- notificationtimestamp
- Adds timestamp of when the user was last notified about the edit.
- loginfo
- Adds log information where appropriate.
- tags
- Lists tags for the entry.
- expiry
- Adds the expiry time.
- Värden (separerade med | eller alternativ): comment, expiry, flags, ids, loginfo, notificationtimestamp, parsedcomment, patrol, sizes, tags, timestamp, title, user, userid
- Default: ids|title|flags
- wlshow
Show only items that meet these criteria. For example, to see only minor edits done by logged-in users, set wlshow=minor|!anon.
- Värden (separerade med | eller alternativ): !anon, !autopatrolled, !bot, !minor, !patrolled, !unread, anon, autopatrolled, bot, minor, patrolled, unread
- wltype
Which types of changes to show:
- edit
- Regular page edits.
- new
- Page creations.
- log
- Log entries.
- external
- External changes.
- categorize
- Category membership changes.
- Värden (separerade med | eller alternativ): categorize, edit, external, log, new
- Default: edit|new|log|categorize
- wlowner
Used along with wltoken to access a different user's watchlist.
- Typ: användare, genom användarnamn
- wltoken
A security token (available in the user's preferences) to allow access to another user's watchlist.
- wlcontinue
When more results are available, use this to continue. More detailed information on how to continue queries can be found on mediawiki.org.
- List the top revision for recently changed pages on the current user's watchlist.
- api.php?action=query&list=watchlist [open in sandbox]
- Fetch additional information about the top revision for recently changed pages on the current user's watchlist.
- api.php?action=query&list=watchlist&wlprop=ids|title|timestamp|user|comment [open in sandbox]
- Fetch additional information about the top revision for recently changed pages on the current user's watchlist, including when temporarily watched items will expire.
- api.php?action=query&list=watchlist&wlprop=ids|title|timestamp|user|comment|expiry [open in sandbox]
- Hämta information om de senaste ändringarna på sidor på den aktuella användarens bevakningslista.
- api.php?action=query&list=watchlist&wlallrev=&wlprop=ids|title|timestamp|user|comment [open in sandbox]
- Hämta sidinformation för nyligen uppdaterade sidor på nuvarande användares bevakningslista.
- api.php?action=query&generator=watchlist&prop=info [open in sandbox]
- Hämta ändringsinformation för nyligen uppdaterade sidor på nuvarande användares bevakningslista.
- api.php?action=query&generator=watchlist&gwlallrev=&prop=revisions&rvprop=timestamp|user [open in sandbox]
- List the top revision for recently changed pages on the watchlist of user Example.
- api.php?action=query&list=watchlist&wlowner=Example&wltoken=123ABC [open in sandbox]
